nate69 said:
I was currently going to purchase the pioneer vsx -1015tx-s. however my home theatre system was Home theatre out of the box. So my home theatre plugins are colored green red etc. and they have two wires going through to them. How can I plug these into any receiver? Because I do not want to go out and buy a brand new home theatre system just for my Xbox 360 to play games in 5.1 through my receiver...so if anyone can help me out that would be awesome.
Doesn't the Xbox have a digital audio output for connection to a HT receiver? If so, then be just be sure whatever receiver you buy accepts it.
Barring the digital output on the entey level 360 you'll have to use whatever analog outputs you have. Check your owner's manual to see which color/plug corrolates to what channel they handle. Odds are you can purchase converters at RatShack to convert these to six RCA plugs so your receiver can accept these. Remember, this base unit was designed to beused with computer/game speakers, not a HT receiver.
Once you have the analog channels identified you'll need to feed them (through the needed adapters) to the correct RCA analog inputs on the back of your receiver. Again, check your manuals for theese. You will need to need to be aware that the level of the Xbox signal will be of a much higher level then the receiver was designed for so you'll have to be careful with the levels. You could easily overdrive the receiver.
But, If your receiver doesn't allow a direct analog connection of the six analog channels then you're SOL. Many entry level receivers and/or HTIB units don't.
Actually, the digital output on the premium Xbox would be a worthwhile step up if you want to play it through a receiver instead of a computer speaker. With that, you can play it with virtually any HT receiver.
