Hello All,
Looking to put together a second system and would like to know which companies are offering the best calibration/EQ systems. Specifically which offer the best subwoofer EQ control. The Velodyne SMS would be cool but I'm more curious about what is already built into the current stuff on the market.
Are you talking about subwoofer EQ systems in receivers? If so, nothing is going to compare to the Velo SMS. EQ'ing lower frequencies is much harder than the upper end of the spectrum. Anything in a receiver is going to be for EQ'ing the entire frequency spectrum.
I have had good results with Audyssey, which can be found on both Onkyo's and Denon's. There is also a review on audioholics of the Denon 2308 that mentions how well the EQ performed. But bear in mind, none of these EQ's is a replacement for the SMS. I think the YPAO from Yamaha and the MCACC from Pioneer are not as good as Audyssey. From the reviews I've read, they are not as accurate and don't seem to yield as good of results.
If you really want an EQ system on the cheap, your best bet is to buy a behringer feedback destroyer and take measurements of your system. These can be had in the 100 - 200 price range and you could still buy a budget receiver in the 500 - 600 range. I'm not sure if the computer software you will need will cost extra. You may also need to budget for a mic.
