Auralex DST-RKIT 12x12x1 Inch Diffusive Sound Tiles (36 Pack)
The Tiles are new in box. Best online price is 99 dollars. I sell these for 35 dollar
From Auralex Website :
The newest member of our diffusor family is the Diffusive Sound Tile Reflector, or DST-R.
Yes, you should confuse it with our new Designer Series Treatments (DST) because it is
intended as the perfect compliment to our DST-112 and DST-114 Studiofoam Panels. The DST-R
Diffusive Sound Tile Reflector is a 1' x1' and is the same shape as a DST-114 panel, except
it is only 1" thick, which makes it a great option when installation depth is very limited,
such as a low ceiling. It, like our MetroFusors, is made from high quality EPS, is lightweight,
can be easily painted using water-based paints ONLY (petroleum-based paints will 'eat' the
expanded Polystyrene), is very easy to install, and is a very low cost diffusive alternative.
The 1' squares can be aligned in a number of ways to create a very designer look, particularly
when painted with water-based paint, and used in combination with DST-112 and DST-114 absorbent
panels.
Note: Do not use Foamtak™ Spray Adhesive to mount the Q'Fusors. Use Tubetak or Tubetak Pro only.
