Audyssey wont turn on
Rblaster85
Hello, I recently purchased a SR5007 and i did the audyssey setup. Before in my menu i had options for audyssey like "flat" "graphic eq", and just "audyssey" i think. I played with some of the crossover settings for my speakers and now the menu just says "off" or "graphic eq". How do I get it to turn back on? I also recently bi-amped my front speakers, not sure if this is a problem too. I am thinking maybe I have to re run audyssey?
Thanks
RYan
One possibility is that after you changed it to another mode and/or made changes it may have "lost" the previously stored settings and you may need to run it again.
Biamping off a receiver really doesn't do much, but on my UMC-200 it has a setting specifically for biamp mode as well and that may affect the use of Audessey, so you may have to re-run it because of that change as well.
