Hi All,
I am new here, and admittedly not an audiophile. So I appreciate any suggestions you have.
Here is the situation:
-Complete Remodel of a 100 yr old house with good bones.
-5 or 5.1 Home theater system (60% movies, 40% music, 0% TV) in the living room of the floor plan attached.
-Walls are open down to the studs, install should be a breeze.
Here is the challenge:
-Speaker only budget of $650 (i am looking at the inwall 6.5" or 8" Polks with 1" tweets on newegg.com and the 6.5" or 8" in ceilings for rear surround, a $170 infinity center channel with a 3/4" tweet and 5.25" mids) on crutchfield, and I don't know what for a sub--if we need a sub)
-All speakers must be in wall/ceiling/floor (this is a girl-fiend mandate)
-Sub woofer placement, there is waynes coat (wood paneling) along the bottom 3 feet of wall and I don't know that an in wall sub will fit in the 10.5" wide panel.
-There is a large (13"x17"x how ever deep it needs to be) heating grate in the floor. We are installing radiant heat so we won't be using this space for heating and so it could be used to hide a sub. Is it a problem that it is in the middle of the room?
-The whole living room opens up into the kitchen as you can see so that probably will affect the acoustics.
Some things about us, like I said earlier we are not audiophiles so even a budget system will sound amazing to us. We don't like a lot of bass (maybe we don't even need a sub with 4 8" woofs and two 5.25" mids??) Also there will be an apartment built below this room so we don't want the bass to be earth shattering and for the budget we are working with it probably won't be.
I trust the name brand Polks but if there is a "generic" complete in wall/in ceiling set up with every thing we need that you Audiophiles like and trust that might be fine too.
Thank you in advance for your help and I'll be here if you have any questions about the space or my horrible not -to -scale drawing.
