Toolboxx
I looking for a new receiver & speakers and need your expertise. I think I have my new speakers picked out but need some serious Audioholics advice! I have a 55” RP Mitsu TV and I’m finally ditching my junky Samsung HTIB! My family room is rectangular (about 400sq ft) but the HT setup will only be using half the room...more like 15x12 or so.
I'm almost 100% convinced on getting the Athena Point 5 MKII's ($199) and adding a Dayton 12" sub but need a new $300 receiver to go with these. I am really new to home audio and while I have a good start at learning from these forums, I'm still kinda clueless.
I was thinking about getting an Onkyo TX-SR573/TX-SR503 or a Pioneer VSK-815. I may be able to stretch the wallet and get the VSK-915 but think the 1015 is out of range. Do you think these receivers will push the Athena’s well? D you have a sound preference between Pio/Onk or have another receiver suggestion to push my Athenas?
The S.5 sat's specs are:
* Frequency Response: 80Hz-20KHz +/-3 dB
* Recommended Amplifier Power: 20 - 100 watts
* Cross-Over Point: 2.0kHz
* Impedance: 8 Ohms Compatible
# weeter: 1" (25mm) Teteron Dome
# Woofer: 4" (10cm) High Performance
The C.5 center channel:
* Frequency Response: 60Hz-20KHz +/-3 dB
* Room Efficiency: 89dB
# Tweeter: 1" (25mm) Teteron Dome
# Woofer: Dual 4" (10cm) High Performance
The Dayton sub is powered...
