Audioholics $25K Recommended Home Theater System
jaxvon
jaxvon
Gene, there's a price discrepancy with the RPG diffusers. In the description section it says $2500 and in the table at the end it says $4000. Which is it?
gene
gene
Audioholics Master Chief
Administrator
Jaxvon;
good catch. It should be $4k. I updated it.
shamus
DONT DO THIS TO ME GENE!!!!! It looks like you swapped out the lpx 510 for the panasonic??????? Do you feel the panasonic is a better choice???
jonnythan
jonnythan
You guys have two different projectors at approximately the same price point for your $12k and $25k systems. Is it reasonable to assume you now recommend the Panasonic over the BenQ since the $25k page was more recently updated?
You'll find us recommending more than one projector in similar price ranges, just like reeceivers and DVD players... Some prefer DLP over LCD, etc. In addition, we often have different people heading up the particular recommendations...
So check it out, compare, contrast, read our reviews where possible and enjoy.
