Basic practical issues
Hi,
The posted guide provides a great technical overview of the various interconnection types, however I'm after some basic info on interconnection and have struggled to find this anywhere !!
What is the best practice for providing access from the Receiver to the speakers, projector, tv etc if they are not co-located, as is often the case.
Should I use wallplates with the various correct interfaces - banana sockets for speakers, RCA sockets, S-video sockets etc, then run short jumpers from the receiver to the wall plates and of course, the same will be required at the projector or speaker end.
If wallplates are the way to go, what good quality ones are available.
Or do I just cut a large hole in the wall and run all the various cable thru it, with corresponding smaller holes at the other end. Thus no joins. I dont think the better half would think this is the way to go however.
thanks for any advice
