Those looking for a new pair of headphones often encounter themselves with several options making it difficult to decide in right away. If you are like me, you will take your time to carefully analyze the pro's and con's of each model in order to make the best choice so there are no regrets later down the road. I was in that same situation a while ago and this overview is about one of the models I was looking at. Meet the Audio-Technica ATH-MSR7GM SonicPro Over-Ear High-Resolution Audio Headphones.
These headphones are designed to reproduce Hi-Res Audio, and are outfitted with exclusive 45mm drivers that Audio Technica calls True Motion Drivers. These drivers, according to the company, utilize lightweight voice coils, a custom-mounted printed circuit board and specially designed diaphragm to improve transient response and minimize sound distortion for rich, detailed audio reproduction. The ATH-MSR7 headphones also feature multi-layered air damping technology for extended mid-to-low frequency response.
The housings are constructed of an aluminum/magnesium mix to provide a lightweight, rigid structure and reduce resonance. There are three vents within its layers to control air flow and improve dynamics. You will find convenient stuff like flexible swivel, with soft, memory foam earpads and headband to ensure good comfort during extended listening sessions. In-line controls and microphone for compatible smartphones and other devices are also on-board. So there you have it. If you are in the market for a new pair of headphones, maybe you should add the Audio-Technica ATH-MSR7GM SonicPro Over-Ear High-Resolution Audio Headphones on your short list.
ACCESSORIES INCLUDED:
- Protective pouch
- Condenser
- Polar Pattern (Microphone)
- Omni directional
FEATURES:
- Newly designed 45 mm True Motion Drivers deliver Hi-Res Audio reproduction.
- Multi-layer Air Damping Technology comprised of a layered aluminum/magnesium housing and triple-vent system reduces unwanted vibration and controls air stream for high audio clarity.
- Ultra-comfortable, soft, memory foam earpads and headband.
- Three detachable cables: standard 1.2 m (3.9') and 3.0 m (9.8') cables, plus 1.2 m (3.9') smartphone-compatible cable with in-line controls & mic.
- Stainless steel acoustic mesh resistor provides improved high-frequency response, while bass acoustic resistor delivers accurate low-frequency response.
SPECIFICATIONS:
- Type: Dynamic
- Driver Diameter: 45 mm
- System Frequency Response: 5Hz - 40,000 Hz
- Microphone Frequency Response: 50Hz - 4,000 Hz
- Maximum Input Power: 2,000 mW
- Sensitivity: 100 dB/mW
- Impedance: 35 ohms
- Weight: 290g
- Cable: Detachable 1.2m (3.9') standard cable, detachable 3.0m (9.8') standard cable, detachable 1.2m (3.9') cable with in-line controls and microphone for smartphones.
- Connector: 3.5mm gold-plated stereo mini plug, L-shaped.
Price: $249.95/each.
