Audio-Technica ATH-CKP500 In-Ear Heahphones Overview
HTKamikazee
Audioholics Sheriff
Haven't found the right headphones to use at the gym? The Audio-Technica’s ATH-CKP500 active-fit in-ear headphones feature ergonomic C-shaped eartips that nestle naturally in the outer ear to hold the headphones securely in place.
Their angled housings direct the cord behind the wearer’s neck so it stays out of the way. In addition to standard sound isolating eartips, the ATH-CKP500 comes with newly designed ridged eartips that allow the user to hear ambient noise like traffic or other runners for safer use outdoors.
The headphones have IPX5 Waterproof Certification that allows them to be washed after use. They are available in black, red, white and blue, and come with a cord clip and 2-ft. (0.6 m) extension cord. While these have been on the market for some time, I still find them to be very very effective and comfortable. So, if you are in the market for a new pair, check these ones out.
FEATURES:
  • Ergonomic C-shaped eartips contoured for maximum earpiece stability and comfort nestle naturally in the outer ear to hold earphones securely in place
  • Ideal for active use, jogging, sports
  • Angled housing directs the cords behind your neck
  • Asymmetrical cable design keeps cable out of the way and helps prevent tangles
  • Superb sound quality from pro audio leaders
  • Lab tested and certified IPX5* waterproof rating allows headphones to be washed after use
  • Included XS/S/M/L interchangeable ear tips for sound isolation, and newly designed ridged ear tips that allow ambient traffic noise for safer use outdoors
  • Offered in: black (ATH-CKP500BK); red (ATH-CKP500RD); blue (ATH-CKP500BL) and white (ATH-CKP500WH)
SPECIFICATIONS:
  • Type: Dynamic
  • Driver Diameter: 8.8 mm
  • Frequency Response: 20 - 23,000 Hz
  • Maximum Input Power: 40 mW
  • Sensitivity: 100 dB/mW
  • Impedance: 16 ohms
  • Weight: 8 g
  • Cable: 0.6 m (2'), U-type
  • Connector: 3.5 mm (1/8") mini-stereo
  • Accessories Included: C-tips (S/M/L), ear tips (XS/S/M/L), ridged ear tips (S/M/L), 0.6 m (2') extension cord, cord clip
PRICE: $59.95
