To those who haven't discover the beauty of vinyl, this is their opportunity to discover it. And those who are thinking about going back to their roots, maybe this us the time to rediscover the “warmth” of vinyl records with this an affordable, fully automatic belt-drive turntable like the AT-LP60RD from Audio-Technica.
This colorful product is equipped to play both 33-1/3 and 45 RPM records, and features a built-in switchable phono preamp that enables it to be connected directly to a computer, home stereo and other components, even if they have no dedicated turntable input.
The AT-LP60RD comes with an integral Audio-Technica Dual Magnet™ phono cartridge with replaceable stylus. There you have it, folks! With affordable products like this one, there should be no excuse not to step into the vinyl world. So, do yourself a favor, get a turntable and start enjoying some vinyl nirvana.
Take a look at the following features and specifications for additional information.
FEATURES:
- Fully automatic operation with two speeds: 33-1/3 and 45 RPM
- Professional aluminum platter
- Included cables connect to your stereo or powered speakers
- Integral Dual Magnet™ phono cartridge with replaceable stylus
- Switchable built-in pre-amplifier with line-level RCA output cables
- Anodized red finish adds bold, metallic style to any entertainment system
- Available in silver (AT-LP60), blue (AT-LP60BL) and red (AT-LP60RD)
SPECIFICATIONS:
- Type: Belt drive turntable, fully automatic
- Motor: DC servo-controlled
- Speeds: 33-1/3 RPM, 45 RPM
- Turntable Platter: Aluminum
- Wow and Flutter: Less than 0.25% (WTD) @ 3 kHz (JIS)
- Signal-to-Noise Ratio: >50 dB (DIN-B)
- Pre-amp “PHONO” Output Level: 2.5 mV nominal at 1 kHz, 5 cm/sec
- Pre-amp “LINE” Output Level: 150 mV nominal at 1 kHz, 5 cm/sec
- Phono Pre-Amp Gain: 36 dB nominal, RIAA equalized
- Power Supply Requirements: 120V AC, 60 Hz, 3W
- Dimensions: 14.17" W x 3.84" H x 14.02" D
- Weight: 6.6 lbs.
- Accessories Included: Dual RCA (female) to 3.5 mm (1/8") mini-plug (male) stereo adapter cable; dual RCA (female) to 3.5 mm (1/8") mini-plug (female) stereo adapter cable; 45 RPM adapter
- Replacement Stylus: ATN3600L
PRICE: $129.95
