Audio-tadpole looking for advice on system.
Tandyman100
Combo-pack introduction/asking for help thread here, have fun.
Howdy, I joined the forums hoping I could find the best way to get the most out of my existing system without spending much money, being a jobless teen stuck in the middle of Kansas. I've been playing piano for about 9 years, guitar for about 4, and I think I've developed a decent ear over the years because of it.
After listening to a pair of stereo computer speakers for ages, I found an early-2000s era 2.1 Boston Acoustics powered set. Had fun with that, first time I'd ever listened to a subwoofer. I found myself obsessed with 'feeling' the music, and ended up duct-taping the speakers to the headrest of my office chair, and making a duct tape 'sling' that help the sub just behind my lower back. Then it died.
Not being able to afford a new system, I just used my dads, which is:
A pair of Pioneer CS-1000s (50watt, 8 ohm) connected to a
Pioneer SA-130 amp which is then connected to a
Sony CDP-C400, Sansui P-D20, and a Sony TC-WR545 which I'll be swapping out with my Technics SL-6 because of the nifty programmable option and ability to play 45s.
Well, that's what I've got now. When I have a hankering for some music-listening at parent-annoying levels I just drag my laptop down and plug-er in with a stereo 3.5mm-to-RCA adapter. Classy.
What I'm trying to do is cobble together my own system for use in a 20'x20' room, shaped like a square with one corner cut off, and a wart on the opposite corner (best way I can find to describe it), and thick carpets.
My budget is rather limited, at less than $200, so I'm mostly wondering what I should look for at garage sales, craigslist, and goodwill to get the best bang for my limited buck.
I'm not incredibly picky, since I think that my $15 skullcandies are amazing sounding (First in-ear earphones I've ever had, just stuck with them since they're adequate).
Oi... I hope saying that doesn't get me laughed off the forum :p
Well, greetings and thanks in advance for any advice.
If you can pick up some older 80s Infinity speakers or similar, usually with rotted foam on the bass driver, you can usually buy a foam repair kit for around $10/speaker. Providing everything else is working, you can usually get out the door with these pretty cheap. I saw a set fitting that description in my neighborhood sell for $13!, so total would be around $33 and would be a good start. Then any old receiver that you can find that works. I've picked them up at yard sales as low as $10.
baniels
baniels
To add to that, replacing the caps in the crossover can also help. I had some 1970's Utah 3-ways from a garage sale find - replacing all of the (few) crossover components cost me ~$10 and made a noticeable improvement (No ABX though ;))
Used is one route, but DIY is another. For something like ~70/pair, you can build Paul Carmody's Overnight Sensations. While they're not for PA level sounds, they are a bite-sized gateway to high quality DIY.
bikemig
The best deal in audio is a good pair of headphones. I think the Audio Technica ATH AD 700 are amazingly good. They cost $90 on Amazon but you may be able to pick them up for less on the net, Amazon.com: Audio Technica ATH-AD700 Open-air Dynamic Audiophile Headphones: Electronics. They're also fairly easy to drive and so your laptop headphone out should be able to drive them easily. Plus you won't be able to drive your parents nuts when you want to crank up the volume which I realize may not be a selling point as far as you are concerned, :D. You could couple this with a decent pair of powered speakers and stay within your $200 budget. These run $117, Swan M10. The Swans are well regarded and the audio insider has a 30 day money back guarantee.
