bigpapa said:
I'm expecting to pay a few hundred bucks for software and a maybe another few hundred for a good mic, but I don't know if I need a new sound card or upgrade to my laptop.
Anybody point me in the right direction?
Here is a list of cost effective hardware for your laptop. Prices listed are averages.:
Measurement equipment:
SoundBlaster Audigy 2 PCMCIA card ($90)
*Behringer ECM-8000 Measurement Microphone ($50)
**Rolls MP-13 Mini-Mic Preamp($70)
Microphone Stand(boom type recommended)($25)
XLR Microphone Cable($10)
Other various cable(s)($15)
*ECM-8000 is generally accurate +/- 1dB from 20Hz-10,000Hz with no correction. A 2 or 3 dB variation may occur by 15,000Hz on some samples, though many may never exceed a 1.5dB error. If you require a known +/- 1dB accuracy throughout the entire 20Hz-20,000 Hz range, you will have to get the item calibrated. This service starts at about $40 USD.
**The Rolls MP-13 needs to be plugged into an outlet. If you need a portable battery powered microphone preamp with phantom power(
the ECM-8000 and other such mics will require it), you will have to get a product such as Rolls MX34($90). Alternatively, you can construct a small battery case with parts from Radio Shack to supply the MP-13 with the required 12VDC, or use one of those portable rechargeable universal battery packs made for portable DVD players -- some of these have 12VDC output. About $50-$60 USD for one of these units.
-Chris
