N
NickSmith
So I have two speakers that are 500watts each. I know I don’t have to match that. I also have a receiver that is 50watts x 4 channels.
This is for my motorcycle. Would this set up provide enough sound? I want to play “itty bitty titty committee and the cars near me to hear it, haha.
If not then what power amp do you recommend?
Well, not into the noise polluting thing, particularly from motorcycles which, especially the HD variety, are TFL already :)
However, your speakers merely have a peak power rating of 500w, and a continuous program rating of 125 watts. The sensitivity spec is a better indication of how much amp would get you how much spl. They're 4 ohm speakers so make sure you use an amp rated accordingly. Try using the how much amp calculator here
Have no idea where you'd even put an amp on a motorcycle....
E
enrique chavarry
Look up JL audio.Several amps that will get what you need.Had them on the HD i had.
TheWarrior
TheWarrior
Most motorcycles produce barely enough electricity at idle to keep the battery charged while running all the lights. This is not likely a project you will want to put any more money in to. A much cheaper solution would be to use something like a Harman Go + Play or other portable speakers in a tank bag or whatever.
