I have moved my Late-2007 MacBook running 10.7.5 to be a music server.
This computer has single analog/digital audio out/headphone jack.
I have a 35 mm analog audio jack that splits into left-right RCA jacks which are plugged into my Yamaha stereo receiver. I guess since this is also a headphone port, the level of the output depends on the volume setting on the Mac.
When turned the Mac volume all the way down, I had to turn the Yamaha almost full blast to hear it.
At medium volume it seemed to sound quite good through the Yamaha, which only needed volume similar to, say, the CD player would take.
Is there any downside - distortion or damage to the stereo receiver or bookshelf speakers -- to turning up the volume on the Mac? How far should I turn it up and/or how much of the volume should be made by the Yamaha?
If I get an external DAC to run between the MacBook and receiver and use a digital optical cable plugged into the MacBook's audio out, will it revert to digital line out with no volume control by the MacBook?
