Hey guys,
Just made the account to start this thread.
I'm no audio enthusiast (yet...) but i am a pc enthusiast... dyi overclocker (running a chilly1 evap homemade single cascade
) and general know-how dude.
I can see this scene is quite similar to the pc modding scene, so i shouldn't be too lost in here
Here's my dillema: I've heard $4000 studio sound (a friend's dad is a @home composer)... and i want it
Currently I've a small but mighty Sony hi-fi setup with crappy 5" cones and 3way bass + 1" and 0.5" tweets running from a 150w or so 5cd changer... basic small system, pumps out decent sound (much better then the burly looking 'gansta' systems that look like something of a cannon more then a speaker), surprisingly clear. Problem is - midrange somewhat lacks, bass definitly lacks and one of the tweeters is ripped. I took the thing apart when it was broken, replaced the power cable (utter crap), fuses and the HSF on the amp. Overall satisfactory - but of course distorts like a ***** at higher volumes.
Now, birthday's coming up and i want some serious sound
I mostly listen to 80's,90's trance, rock, but sometimes a bit of jazz and stuff like adriano celentano
I needs me good midrange, quality tweeters and sub. No need for over-the-top power - i know there are 45W speakers out there that run circles around the advertised 500w systems.
I was considering the logitech z-5500, since it is all assembled for me and of course is 250bucks now. After some research, i've come to realize that while these will blow most other pc speaker systems out of the water in all categories, despite the impressive specs, the speakers are 3" alum plugs and and the sub is a plain ol' dirty 10" woofbox. Sinse obviously tiny speakers simply lack the volume to produce good midrange, these are cut-off @ 180hz, that being the crossover to the subwoofer. I don't want a 10" shaking quaking thunderbox to attempt any midrange in my room (unless you can convince me this isn't such a bad idea). ALSO - no need for 5.1 really, i'm not going to set up surround properly since i simply don't have the room for it, 2.1 or just stereo (so long as it does have some serious bass) is just fine for me.
Hence the problem... sub $400 speakers with a good clear amp, preferrably ones that will take sound in over optical or spdf, instead of the regular 3.5mm stereo plug running from my pc...
If this can be done, and will noticeably beat the z5500, please continue reading.
I live in Toronto Canada, so shipping from america or someplace far would be somewhat out of the question unless you can convince me otherwise.
I am more then willing to buy used (heatware under n-sanity: 11-0-0), preferrably with local pick-up or drop-off.
Oldies but goodies are fine, but i'd prefer newer equipment (oldies being 70's advent and such, newer being 95-2008
Amp doesn't need to be anything fancy - i am an eq freak, and always set my equalizer depending on the music im listening to, if this can be done in the actual receiver, great, if not - the pc's drivers will do it just fine
I'm not afraid to do any dyi dirty work, but would prefer not cutting into physical cabinets. Soldering, wiring etc is no problem, i do it all the time.
Please orient me on the price tiers in this industry, what the bang/buck systems are and if anything generally fits my description, please let me know !
Cheers and thanks in advance.
