Audio Equipment with Indoor HDTV antenna
L
longine
I would like to purchase a better quality sound bar or sound base to use with my 61" DLP TV. I do not have cable TV but use an indoor HDTV antenna. I also stream using a ROKU device and also have a bluray player. Is there any kind of interference or incompatibility problem with audio equipment and the indoor TV antenna??
Swerd
Swerd
There are no emissions from audio equipment that could interfere with TV reception.
JMJVK
No reason for this to be the case, however, certain amplified (plugued-in) antennae could be equipped with a questionable quality wall-wart power supply, and one of these, close to receiver's wiring or sharing the same power circuit could cause RF interference.
I use un-amplified antennae on two of my TVs, and if anything, on the channels that do come in, they yield a better result than my digital cable box for both sound and picture.
