Calibrating the audio in AVIA DVD consists of channel identification, polarity tests, level adjustment, subwoofer, noise floor tests, and rattle tests right?
I am wondering what kind of tests is the most effective? and if I only run the basics, will it be good enough?
do you guys recommend me to buy the AVIA DVD for best result or the result won't be significant?
