Anybody has experience using Athena AS - F1s with HK AVR 235... Thanks Kera
K kera Enthusiast Dec 12, 2005 #1 Anybody has experience using Athena AS - F1s with HK AVR 235... Thanks Kera
jcPanny Audioholic Ninja Dec 12, 2005 #2 Athena's and HK I have some of the Athena bookshelf speakers. Those speakers are 8 ohms so you should have no problem driving them with your HK. They play pretty low, but for HT you will probably want a sub to fill in the 20-40 Hz range.
K kera Enthusiast Dec 12, 2005 #3 jcPanny said: I have some of the Athena bookshelf speakers. Those speakers are 8 ohms so you should have no problem driving them with your HK. They play pretty low, but for HT you will probably want a sub to fill in the 20-40 Hz range. Click to expand... Thanks JC, I already have the Mirage S10 which is doing a good job for HT lows. But my Athena Point 5 is not so great for music. That is why I am looking for AS F1 and the sort.. Kera
Sheep Audioholic Warlord Dec 15, 2005 #4 You will be fine. Just make sure you cut the speakers out high, 80hz, to save up some amp for the other channels. The mirage will do an excellent job up to 80Hz. SheepStar
M markw Audioholic Overlord Dec 15, 2005 #5 You can run the F1's full range. I do and the music appreciates that.
