Atdec Telehook TH-2050-VFM Display Mount Review
admin
Audioholics Robot
Staff member
When Atdec was looking for a place to try out their new TH-2050-VFM in the field I started looking around... and found a friend that still hadn't mounted his TV on the wall (honestly, it's getting so bad that a friend of mine actually snapped a pick of this guy's existing TV install and texted it to me). The TH-2050-VFM is a great-looking mount that comes in a combination silver and black color scheme. The articulated arm has three pivot points - one at the wall, one in the middle of the arm, and the last just behind the mounting plate. This is an attractive and highly usable mount. For obvious reasons it would also work well in a corner or a commercial environment as well. It's elegant, beautiful and well-built. In this particular case we were dealing with a TV that was set on top of a fireplace mantel. It was an older flat panel TV, so it had that going for it. It also supported a VESA mounting pattern, so the TH-2050-VFM seemed to be the perfect solution to our desire for a better use of space.
Discuss "Atdec Telehook TH-2050-VFM Display Mount Review" here. Read the article.
arbeck
Has anyone compared these more expensive mounts head to head with the ones from monoprice? I've never heard complaints about the monoprice mounts, and they are a fraction of the price.
