Assembled home theater system (7.2) to complement TSi500 - polk
assembled
Hi,
Everyone I've never had a real home theater system before. But wanted to start off with an excellent one. I really need your help. I was looking at many forums and the suggestion was to buy speakers from a manufacturer and receivers from other manufacturer and never to buy a whole set from the same manufacturer.
I am trying to follow this suggestion and looked at some options but got totally confused. So far after going through many forums, I've decided upon only a single tower speaker [Polk Audio Tower Speaker (TSi500)].
Can some one suggest me what complements this tower speaker? I need receiver suggestions and other speaker suggestions. I want a set up like 7.2 home theater system.
I am fine with your suggestions other than TSI500 too. I just want a 7.2 home theater system, but as mane forums suggested I wanted to buy assembled system instead of buying from the same manufacturer. Please help.
Pyrrho
Pyrrho
You should tell people your budget. Otherwise, they have no idea what to recommend.
Just to be clear: you only need a receiver and speakers? You already have your TV and BD player?
Also, if you are willing to go with 5.2 or 5.1, you can spend more money per speaker and get better ones. So you might want to think about whether you really need 7.2 or not. Additionally, if you buy bookshelf speakers for all channels, you can go with a higher line for the same money as tower speakers. And since you are going to have a subwoofer (or more than one), the main speakers do not need to deal with the deep bass.
assembled
I am fine to spend $1500 CAD to maximum of $2000 CAD.
Yes I have a LG smart LED TV, I watch mostly Blu-ray but all of them are in my external hard drive which I connect directly to my TV. So I just need receivers and speakers.
I don't have a blu-ray player, rarely (very rare) I use my PS3 to play BR disc.
If you think I should go with 5.2, and get better quality I am fine with that, I can buy 5.2 instead of 7.2. I want great quality but I also like the looks of tower speaker at my home which is why I wanted to have at least one set of tower speakers with other book-shelf. Ofcourse I will be buying more subwoofer, and I am good to spend a little more just to have that one tower at my home.
Please let me know what you think.
Pyrrho
Pyrrho
With your budget, I would try to spend as little as possible on the receiver, so that you have more money for the speakers. And I would cut it back to a 5.1 system to be able to spend more on each speaker. This also makes it easier to upgrade, if you get money in the future, as you simply buy the extra speakers for the extra channels, if you wish. If instead you buy lesser speakers, then a future upgrade would involve getting rid of some of the gear you are buying now, which will almost certainly mean that you will be losing money. I also do not think that the extra surround speakers are that important, though this will in part depend on how you set things up. In my home, I had a 6.1 channel system, and was so unimpressed that when I upgraded my receiver, I did not bother to change it to 7.1 (which would have involved moving some furniture). I now have gone to a 5.2 system, as my new receiver cannot do only 6 channels (it can do 5 or 7, but not 6). But I digress. If you buy only 5 speakers, you can spend more money on each one, getting better ones, and I think that will matter more than having 2 more channels.
I am not familiar with stores in Canada, so it will be difficult for me to give very exact advice on what to get. (But if you have links to stores in Canada that are worth buying from, please feel free to post them so that I and others can get a better idea of the products available there and the pricing there.)
I would probably go with either an inexpensive Yamaha (I personally have a Yamaha, in large part because I like their feature set and price and, judging from online complaints about various brands, Yamaha seems to be as reliable as you can get) or Pioneer receiver that had all of the features I really needed, keeping in mind that every dollar spent on it means less for the speakers. And speakers matter more for the sound than the receiver. So I would skip any extra features that I only kind of wanted, but did not really need to have, if that savings will be enough to go up to better speakers that will significantly impact the sound.
Another reason to spend as little as possible on the receiver, and as much as you can afford on speakers, is that when, in the future, you decide you need some new feature that is not available now, it is the receiver that you will be replacing, and you will be able to continue using the speakers. So an investment in good speakers gets you better sound now, and the money in them will not be lost when you upgrade your receiver for newer features.
The best way to select speakers is to go out into the world and listen to as many types of speakers (e.g., ribbon, horn, dome, whatever) as you can find, of as many brands as you can find, with music with which you are familiar, of all types of music to which you listen (making a CDR for this is a good idea).
Let us go back to one of your original questions. The speakers that match the Polk TSi500 tower speakers are other Polk TSi speakers. You basically want, particularly for the front speakers, them to have the same tonal qualities. This means that you want them "voice matched", which typically means that they have the same tweeters, and often the same mid-bass drivers. Ideally, it would be identical to the front right and left speakers, but many people do not choose to do that because they want their gear to fit on furniture that they have or want. (In my case, I use identical bookshelf speakers for all channels [other than subwoofers, obviously], so I have perfect voice matching. I will NEVER go back to having merely "voice matched" speakers, but most people are fine with just having "voice matched" speakers.) Now, I am not a fan of such low end Polk speakers (I would want the RTi line or higher), but if you like them best of the speakers you have heard in your price range, and if you have listened to a wide variety of speakers in your price range, you should go ahead and get what you like. (After all, it is you who will be listening to them, not me.)
I see from Polk's website that they make matters more confusing for what they consider to be "voice matched":
TSi | Polk Audio®
However, the subwoofer does not need to match the other speakers in such a way, and so you are free to select any brand you want. If you were in the U.S., I would recommend buying SVS, but I believe that the cost in Canada is higher and may be out of your price range. Polk is not usually what you will find recommended for a subwoofer, though if you got one of their higher models at a very low price and could not afford a better one, it might be okay.
assembled
Floor Standing Speakers Review 2014 - TopTenREVIEWS
This is the website where I got the idea that TSi is one of the best speakers around. I never knew about the RTi lines or the other higher ones, after checking them I just changed my entire plan. I am going to follow what you said and concentrate on buying better quality speakers now and later increase the number of speakers. As my budget is now $2000 max, would it be better if i start with 3.1, so I can start with good quality speakers and may be next year I can add 2 more. As I said earlier I always wanted to have tower speakers at my place, so can you please suggest me what I should start with. You would have known by now that my knowledge on speakers is very less, which is why I thought TSi is the highest quality.
It would be great if you could suggest me speakers (3.1 with one tower), sub woofer and receiver.
I am planning to drive to US for blackfriday, so i think I will look around for better deals based on your suggestions.
It is really funny that i started with 7.2 and now I am settled with 3.1.
I will go the store as soon as I get a reply from you and try out the speakers you suggested.
Jimz711
Those reviews are not based upon anyone actually listening to the speakers but the specs, size of drivers, etc. which when you think about it is a fairly laughable way to rate speakers.
Pyrrho
Pyrrho
Jimz711 is right, that rating site is not good. Speakers should be judged on performance, not the number of drivers or what they are made of. And it should be actual performance, not claimed performance in the specifications. In other words, people should listen to them and, ideally, measure their performance with test equipment.
I would not trust the ratings at that site at all.
Again, the best way to select speakers is to go out into the world and listen to as many types of speakers (e.g., ribbon, horn, dome, whatever) as you can find, of as many brands as you can find, with music with which you are familiar, of all types of music to which you listen (making a CDR for this is a good idea).
Now, professional reviews, in which the reviewer actually listens to the speakers and measures their performance, can be useful, both because they may discover a shortcoming that may not be obvious on a first audition, and also because such reviewers have typically listened to many different speakers, and therefore are likely to be able to point you in the direction of some speakers that you will want to add to your list of speakers to audition for yourself. You will want to audition them for yourself, because you are the one who will be listening to them, not the reviewer, so your opinion of how they sound is what matters most.
For example, those running this very site do such reviews; take a look:
AV Product Reviews: Speakers, Amplifiers, Receviers | Audioholics
You might want to look at reviews of speakers there that are in your price range, and if any of the descriptions seem like they would be good, try to find a pair to listen to for yourself. There are other web sites with such reviews, in which measurements are taken with test equipment; those are generally the most useful reviews, as measurements can show problems that someone might not notice in their particular room with the specific music that they chose to use to listen to the speakers.
assembled
Hey guys so I listened to Klipsch - RF800B and it was really good. One speaker is sold for $500 CDN, do you think it is a good deal? But with my budget of $1500, I can only get one of these, is it worth to buy RF800B? If I buy one how can I complete my system. I am not sure.
I was planning to go all polk, if i am not buying Klipsch.
polk CSiA6 - $399
polk RTiA3 (pair) - $399
polk FXiA6 surround (pair) - $499
Is the above good? or should I just buy
polk CSiA6 - $399
2XKlipsch - RF800B - 2X$500
and may be after a year I can buy surrounds?
I am yet to decide on receivers and woofer. Hope you can help with this please.
assembled
I checked out Polk Audio DSW PRO 550wi sub, i liked it. Let me know if I can go with this.
assembled
If RF 800B is really worth it, then I can just buy 2X RF800B and one good sub and a receiver for now. I am saying this because the total cost of this setup itself will cross my budget of $1500. I can add more speakers in the future.
zieglj01
zieglj01
You said, you were willing to go up to $2000
Do not mix the brands up front - the center series should match the front L/R
Polk or Klipsch, it is up to you - I still favor the Boston A series
Your call
assembled
So finally bought my speakers and I love it.
Front L and R - Klipsch RF 800B
Centre - RC 500 Klipsch
Pioneer VSX 1028 k receiver
I am yet to buy a sub, will do that soon.
I really like my speakers. But I am not sure if i chose the right receiver. I picked the receiver as I wanted to listen more to the speakers as soon as possible. I might change my receiver. I need your thought on the receiver. Is it worth for $500?
