I don't personally but I can tell you that ART is a budget line of pro audio gear something like Behringer but, unlike Behringer, they actually design and develop their own products. Behringer just knocks off the designs of others.
What does "budget" mean in terms of performance? While the pro audio people love to knock the ART microphone preamps, a power amp is pretty much a power amp. As long as it increases the amplitude of the waveforms without changing their shape, it will produce sound like all the other power amps with flat, distortion free, quiet performance. So I would say that sonically, these would be fine.
In a recording studio, the equipment runs all day long day after week after month after year. The budget gear is generally not as reliable as more expensive products. However, in a home application, even the budget units would be more reliable than gear made for home audio applications. So I wouldn't worry about the budget moniker in your application either.
In a nutshell, these amps will probably work as well as any.
There might be some cabling issues. The inputs to the amps are not likely to use RCA. They probably use 1/4" jacks. The speaker terminals are probabaly speakon and/or 1/4" but some pro amps have a way of connecting bare wire as well. At worst, you may need to make up some cables or have them made.
Good luck.
