From the Voice of Experience.
Isolation platforms can be critical for components with high speed moving parts (think those little CD & DVD motors) that can have problems when exposed to vibration. Hence the manufacturers installing vibration dampening devices inside the players.
How much vibration is a problem?
Freight Trains moving at 60 mph every 30 minutes about 1/16 mile from your house.
It takes that much vibration to actually cause a problem greater than the manufacturers internal vibration dampening device. Even so, the failure rate of those little motors in such an enviroment is only about 3 to 5 times the failure rate of those little motors in all enviroments. In other words, 3 to 5 times an infinitely small number is still an infinitely small number.
What does it take to really minimize the vibration problem? Think concrete or marble built into a table. Lots of weight. Maybe 500lbs of weight. The mount between the table legs and table top is a dampening device. In the old days, we used a bladder filled with a silicon gel. Great stuff.
Is such a vibration table practical for home users? No.
An extended warranty on the CD/DVD player would be cheaper than the cost of the solution, if you actually had such a problem. Personally, just buy a good unit with a minimum of 1 year warranty, skip the extended warranty, and trash the player every three or four years.
Now days, I see all kinds of super duper vibration free tables and 3 mm neoprene pads that are "designed" to reduce vibration, even from trains and automobiles.
Wow.
Remember, at 1/2 mile you can still "feel" the train, but that amount of vibration is not greater than a heavy person walking across a wooden floor.
PS: If you actually had a vibration problem, the playback of the CD/DVD's would be having problems long before actual unit failure.
