Thanks for the replies.
I know that no current SSP can handle raw Dolby TrueHD or DTS-HD. All HD-DVD / BD players can output decoded TrueHD or DD+ via SPDIF as 640kb/s standard Dolby Digital as a "backwards compatability" feature, so you don't have to utilize the analog outputs of the player to listen to the TrueHD / DD+ track. That 640kb/s signal compatability is what I don't know, as I've never seen that spec published, and in "Secrets SSP Benchmark" they list it as a test but have never recorded a score for that feature.
Here is a quote from Dolby's TrueHD website:
http://www.dolby.com/consumer/technology/trueHD/AVRs/trueHD_avrs_2.html
"S/PDIF Connection
If your A/V receiver or processor has neither multichannel analog or digital inputs, but is equipped with 5.1-channel Dolby® Digital decoding and playback, you will still be able to enjoy 5.1-channel performance from next-generation optical players. Included within 7.1-channel multichannel Dolby Digital Plus and Dolby TrueHD streams is a core 5.1 mix prepared by the content maker that is used when the player is set for 5.1-channel mode. After playback audio signals have been mixed in the player, the PCM signal can be encoded to a Dolby Digital signal and output from the player via S/PDIF (optical or coaxial) to your connected Dolby Digital A/V receiver or processor."
"In many instances, the audio quality you will experience from this connection may be better than what you would experience during playback of standard-definition DVD-Video discs, especially if the native signal on the disc is Dolby TrueHD or high-bit-rate Dolby Digital Plus. This is a direct result of a higher-quality source signal feeding a Dolby Digital encoder running at 640 kbps—higher than the maximum bit rate on DVD-Video."
