Are Component cables necessary??
U
Unregistered
Guest
Is it necessary to use the red/green/blue cables or can i just use the yellow/red/white?
I know what each is for, but is there actually a physical difference in the two cables? except for the colors of course.
Basically, can i substitute rca for rgb for video from my DVD player?
markw
You should be fine with red/green/blue or even yellow cables. These indicate cables designed for video needs by being manufacturred to a 75 ohm impedance.
The red/white cadles are generally used for audio applications where a 75 ohm impedance isn't required but, then again, they MIGHT be 75 ohm as well. No sure way of telling.
Doufuss
Component cables
Good component cables are designed to carry the much higher bandwidth of the component video signal. There is a good article here in the cable info centre.
If your primary concern is cost, check out Radioshack gold series or Acoustic Research cables. You need a good grade of shielded cable with well made terminals, but you don't have to spend a ton of dough to get it.
I purchased Monster and AR on the same day, and feel I actually got a superior picture from AR. I returned the Monster cable and am very satisfied with AR. $100.00 in savings buys plenty of groceries.
av_phile
You can always try them out. My only criteria for component cables are that they should be identical in construction and length. A 75-ohm cable is i think a minimum requirement for video cables. Then again, I've some people use ordinary RCA cables without questionable 75ohm impedance values or none at all. But it seems they also work.
