Hello Allargon,
Thanks for your thoughts on this; let me reply to some of them as the issue seems to have gotten a bit cloudier for me...
The Panasonic Blu-Ray players all have horrible upconversion according to every professional review out there.
Yes; I have read this too since owning the '10A...hence, why I want to get a good separate upscaling player like the Oppo 983 for DVD playback exclusively -- I'm on their wait list because they're out of stock...
This is true of the DMP-BD10's, 30 and 50.
Right -- hence the reason why I'm not getting another Panny deck even for its bitstreaming output of the new codecs, which I wanted to upgrade this '10A for...
However, they are all fine Blu-Ray players. If you're not seeing good, sharp detail, something else is wrong. I am a big time promulgator of the LG BH200. However, I won't denigrate the Panasonic's Blu-Ray playback capability. I had a DMP-BD10AK for a week. It's got a nice, solid construction to it.
I'm not really seeing a sharp, detailed image -- from MOST of the titles I run this player with; now, some titles have been mind-boggling detailed, such as CON AIR believe it or not, but most titles simply look like what good DVD should in my opinion.
Now, of course, there are other factors at play here: I am running ths '10A in an HDMI loop through an Onkyo TX-SR605 receiver, in which the '10A's HDMI OUT is going to the receiver's HDMI IN and then the receiver's HDMI OUT is going to my Sony SXRD display's HDMI IN...could THIS be degrading the Blu-ray picture I'm seeing somehow?
I'm also engaging Panasonic's "Digital Noise Reduction" circuit (or DNR) when playing DVDs and Blu-rays, and for DVDs, it DOES cut down on artifacts but seems to do nothing with Blu-rays...should this be on or off for high definition playback?
Grain is NOT a defect of the disc. Film has grain. The higher resolution of Blu-Ray (and its defunct relatives HD DVD, HD VMD, D-Theater) means that film scans will show grain.
I am noticing high definition is bringing out the film grain in almost every disc -- while I don't care for it, I totally understand that it's inherent in film...what I'm talking about is annoying, grain-like "flickering" and "dithering" in the background of Blu-ray films played on this deck -- it's a "issue" described by a reviewer who did a review online of the '10A and found the same strange "twitchiness" to even Blu-rays played on the Panasonic...I'll try and find the link to the review...THAT'S why I want to know if all Blu-ray players are created equal...
IMHO, LCD's have the worst PQ of all high definition technologies. Your SXRD (LCoS) has wonderful PQ. You need to get your display professional calibrated--period. The person who said an LCD would help you probably knows LCD's are so poor that you can't tell any difference between good or bad playback.
I'm afraid I don't know what to say about this; I have calibrated my KDS-50A2020 in Sony's Standard picture mode with a calibration disc and don't really want to invest in a professional ISF right now; at any rate, should I be using the set's "Custom" mode instead and engaging features like "Detail Enhancer" or "Live Color," etc? I don't know how to set the White Balance values without a tool, either; can these be left at default of zero?
I haven't reviewed every Blu-ray player. Honestly, I've only played with about 3-4 of them. The reviewers here can assist you with that. I've read many reviews. I've seen very few players (usually the earlier Samsung units having disc compatibility issues) get poor marks for Blu-Ray playback. Most tend to vary with startup and loading times and feature sets rather than Blu-Ray playback PQ.
Yes, I have read that too, that most of the issues come from playback loading times and firmware mishaps and such; I just need to know if there is tremendous quality differences in picture output between these players...
I bet if you got that Denon player and hooked it up the exact same way, you would have similar problems. It may be your Onkyo receiver setup (as Clint mentioned in a previous post).
Okay, now this is disheartening...what could the receiver possibly be introducing in terms of "robbing" the Blu-ray discs from resolution, quality, intensity, etc? If Denon's $2000 player performs the same way as the Panasonic, why do they charge such a premium for those players?
It could be your display settings. Again, let us know if your set is calibrated!
My set has been self-calibrated to basic values using a "DiscWasher" system disc; I am using the "Standard" picture mode and believe it or not, the settings were not far off the Sony default values for the basic settings according to what the calibration system told me:
Mode: Standard
Iris: Auto 1
Color Temp: Neutral
Picture: 80
Brightness: 53
Color: 50 (Sony's default seemed fine)
Hue: 0 (Sony's default seemed fine)
Sharpness: 50 (according to the calibration patterns the default of "50" didn't matter or seem too high)
Noise Reduction: Low
