I have been going back and forth as to what to replace my Anthem Statement D2V/A5 audio system in order to take advantage of Atmos and DTX as well as to pass through 4K. My front speakers are Paradigm S8 (l and r) and a C5 for the center. I would be using a 5.1.4 set-up. I am curious about going with Arcam equipment. The AVR 850 has 7 channels of amplification, so to achieve 5.1.4, I would need an addition 2 channels of amplification. With a used 2 channel (Arcam DiVA P90 or a Bryston (3B-ST) that combo would be a little under $7,000. If I went with the Arcam AV 860 avp and paired it with a Monolith 9 channel amp, the cost would be around $7,500.
Is the Monolith an equal to and/ or better amp than the internal 7 Class G amps of the AVR 850 plus the Arcam/Bryston route?
Also, the cost of 9 XLR cables can add up. Would running Monoprice or Blue Jean XLR cables be a good choice, or should I be considering a higher priced XLR cable?
Thank you!!!
Lew
