5 5th Beatle Junior Audioholic Feb 17, 2005 53 0 8 71 North Atlanta May 13, 2005 #1 My repair tech tells me if the tweeter and bass need replacing on these vintage AR2x loudspeakers, it could be a tall order. Looking for a replacement source(s) should it come to that. Thanks for any and all suggestions.
Buckeyefan 1 Audioholic Ninja Feb 24, 2005 4,983 0 63 TBDBITL May 13, 2005 #2 5th Beatle said: My repair tech tells me if the tweeter and bass need replacing on these vintage AR2x loudspeakers, it could be a tall order. Looking for a replacement source(s) should it come to that. Thanks for any and all suggestions. Click to expand... Try these: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=3275&item=5774585043&rd=1 http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=71571&item=5774391827&rd=1 (if those tweeters don't fit, there's plenty more on ebay) You may want to purchase some wood filler since the holes probably wont match up in your speaker cabinets. Get a cordless drill and some wood screws, and some electrical tape (or soldering gun and solder if you know what you're doing) and you're back in business.
L Leprkon Audioholic General Sep 10, 2004 1,424 0 0 May 14, 2005 #3 www.madisound.com has a pretty good reputation for replacements. www.***************** is another reputable source.
Buckeyefan 1 Audioholic Ninja Feb 24, 2005 4,983 0 63 TBDBITL May 14, 2005 #4 Leprkon said: www.madisound.com has a pretty good reputation for replacements. www.***************** is another reputable source. Click to expand... www.partexpress.com no $ex allowed
