Apologies to everyone re: THX viewing angle
jostenmeat
I've stated a bazillion times here that the THX viewing angle recommendation to be 36 degrees.
I've been corrected in the last 24 hours, and now know that 36 degrees is the THX rec for the back row of a theater.
The THX rec is actually at 40 degrees. So, I guess my preference for 42 degrees is not that far off from the recommendation after all.
Sorry. Not that it would change my advice a whole lot, but I wish was corrected earlier! :eek::eek:
BMXTRIX
BMXTRIX
That is contrary to what this states...
http://myhometheater.homestead.com/viewingdistancecalculator.html
It lists THX minimum viewing angle as 26 degrees and recommend at 36 degrees.
Not sure where we've seen a jump in this angle, but the typical commercial theater puts center row seating at 36 degrees, or right about 1.5x the screen width.
EDIT: This post does a far better job with the explanation: http://www.avsforum.com/avs-vb/showthread.php?t=854721
I hate linking to AVS, but in this case, the information is excellent. 36 degrees is the back of the recommend THX spec, not the back row of a theater. The general THX spec is from 40 to 36 degrees optimally, but for home theater, it tends to be towards 36 degrees to to visual acquity being right in that area as well.
jostenmeat
from your first link:
"THX requires that the back row of seats in a theater have at least a 26 degree viewing angle and recommends a 36 degree viewing angle."
When they specify 36 degrees here, they are not implying the back row of seats? If that's the case, the explanation could be improved.
If you say that 36 is the "back" of the spec, what is the front? 40? Therefore, would you say the THX rec is 36-40?
Your second link seems to be primarily interested in 2.35-2.40 AR.
post #4 refers to this diagram:
It does say there "Recommended distance from screen to farthest seat". The title of the image is THX Cinema Certification: Audience viewing angle for the Cinemascope image".
post #5 says: "I was going to say, I thought THX specified minimum viewing angles, not maximum angles."
post #6 says: "If I remember correctly 26 deg. is in the acceptable area but 36 deg. is in the recommended area, farthest seat."
I was also given this link when I was "corrected" (besides the Garci diagrams).
http://www.thx.com/home/setup/display.html
Whatevs. Thanks BMX.
AVRat
AVRat
At THX's site I don't find the minimum "Certified" angle, just the 36 degrees recommended to the farthest seat. I think the 40 degree recommendation is to minimize the "tennis match" effect. The site really doesn't set things in concrete. I'm currently at about the 26 degree mark and find the image quite immersive.
BMXTRIX
BMXTRIX
What I find interesting is that right at the start of the THX link...
They do show that seating from the TV should be at 40 degrees or less viewing angle and recommend 6-9 feet from a 60" diagonal. 36 degrees is at 6.7' from that size screen.
This also means, that the 6-9 feet represents a range from 40 degrees to 26 degrees (or very close).
In simplest terms, 26 degrees is the furthest that THX wants you to view a screen from and 40 degrees is the closest. 36 degrees is towards the front of that range, and is where I tend to stick and likely will stick for a number of years.
Since most people tend to not always watch the greatest content, and want versatility in their setup and already tend to think that a 60" display is 'HUGE!' - it makes sense to try to talk them into 1.5x width as their viewing distance. Or, at least the distance to their primary seating location - typically the middle seats.
Then, you have to balance it all against personal preference. THX is a guideline, and it's one that many theaters follow. So, it's the personal preferences of individuals working within this guideline that truly determines screen size.
Some people also look at their environment which is often less than ideal. If your room is a bowling alley, then the screen either fills an entire wall and looks lousy, or you make it smaller and must sit closer - yet the final result fits the room far better.
There's a lot of science to it all, but the real art of it is the allowance of personal preferences to be the true dictator of size.
lsiberian
lsiberian
While you guys argue over viewing angles. I"m gonna pop some popcorn and enjoy my non THX angles.:p
Some people watch movies and other talk about watching them. Which would you rather be?:)
What a guy:D
I like doing them both but not at the same time:D
BMXTRIX
BMXTRIX
I'd MUCH rather be watching them. I get by though when I sneak a few minutes on forums in the middle of my working day. I certainly enjoy talking about home theater (esp. front projection) when I can't be in the middle of it all.
No home theater for me today though - gotta work... Until 4:00 - then I get to see Star Trek. First time seeing a movie of my own choosing in a theater in half a year or so.
You really are a poor schlub if you aren't enjoying full THX standards within your home though. :) :D ;) j/k
