APC S15 same as APC J15?
W
wanaco
I was about to buy the APC S15, but I noticed the APC J15. They look the same to me. I am wondering if they are the same inside. Check this website out:
http://www.htpcnews.com/main.php?id=ces_2006_8
I also was looking at the specs of the J15 and they look the same as the S15 check them out:
http://www.brightandsleek.com/ProductDetails.asp?ProductCode=APNJ15&Show=ExtInfo
BEST OF ALL, did you see the price of the J15?
I know the administrator Gene I believe! uses the APC's so can you guys tell me if they are the same?
Thanks
W
wanaco
I called APC AV and they told me that the difference between the H and the S is that the H when on UPS mode does not produce a sine wave.
I ended up buying the S15
Space Ace
Kind of funny that the J15 is not on APC's website anywhere.
