Anyone program a Marantz remote to operate a Oppo 93?
PHANofPHUNK
PHANofPHUNK
contacted oppo and they couldn't help. And for some reason Marantz is closed today...
thanks!:)
No problems programming mine on my URC R50 or Marantz RC2000 MkII. I had some Emotiva codes not work at all on my URC though.
PHANofPHUNK
PHANofPHUNK
Do you have the numerical code to enter into the marantz remote?
No, I had to manually program the whole thing for the Marantz. For the URC it has generic Oppo codes and I manually programmed the additional ones I wanted.
PHANofPHUNK
PHANofPHUNK
You mean porgtam the play button stop buttonnetc... with diffrent codes? Or did you use the learning method, point remotes at each other?
