Anyone know the enclosure volume and tuning of a Klipsch KSW 12
V
Vart
I'm just curious what the volume and tuning of the enclosure for my Klipsch KSW12 is. I've searched around and can't find any info on this. I know I could measure the dimensions and figure it out for myself, but I would have to take out the sub since I don't know the wall thickness.
no. 5
no. 5
how accurate of a measure do you need? (and why? :confused: )
I'm guessing that it would not be a huge deference in internal volume between .25" .75" and 1.0" wall thickness, if you are feeling like a doing lot of math, you could figure out what the volume would be with the thickest and thinnest wall, then you would at least know it's internal volume is somewhere between their.
V
Vart
I was just curious what it was. Maybe someday I'll get ambitious and pull the sub out and measure for myself.
V
Vart
# Power handling, continuous: 105 watts; 22 - 125Hz at less than/equal to 1 percent THD
# Power handling, dynamic: 440 watts at less than/equal to 1 percent THD
# Frequency response: 29Hz-120Hz +/-3dB
# Sensitivity: 113dB SPL 1/8 space, 1 meter
# Low pass crossover: Continuously variable from 40-120Hz, 24dB/octave slope above 120Hz
# Woofer: K-1071-K 12" (30.5cm) down-firing fiber-composite cone
# Amplifier: Class A/B discrete MOSFET outputs
# Phase: Switchable 0 or 180 degrees
# Enclosure material: MDF
# Enclosure type: Bass reflex via rear-mounted port
# Outputs: 2) High level speaker terminals, high pass filtered at 100Hz, 6dB/octave slope
# Inputs: 2) Line level/LFE RCA phono jacks and 2) High level speaker terminals
# Auto power on: 2 Second ON delay, 15 minute OFF delay
# Dimensions: 17 x 15 x 15 inches
# Weight: 35 pounds
# Finishes: Matte-finish Black vinyl
# Voltage: 110/120 VAC/60Hz
# Export voltage: 230 VAC 50/60Hz
annunaki
annunaki
Moderator
Remove the woofer. Measure the dimensions inside. Measure the length of the port as well as the diameter (if ported). Get back to me with that info and I can tell you what you are looking at.
V
Vart
Yeah, I can figure it out if I have the measurements. I'm just too lazy to pull the sub. :D
