Any one had this issue before??
Franin
Franin
I have a jvc hd 35O and recentley everytime I turn it on I get a once off tap when the lens opens. I'm curious to know if anyone knows what it could be and has had that problem before ?
Thanks
jostenmeat
Thanks
Hi Franin, I have not, and I am guessing it is likely because I don't have a feature that you do? An automatic lens cover, which automatically opens when you turn it on, and likewise closes when you power it down?
While I don't yet have a troubleshooting solution, I'll keep my eyes out for you.
Well, the tap . . . hmmm . . . I have an idea, get anything that can record the sound, and record that tap when you fire it up. Link the sound file at the AVS thread, and I bet someone might know what it truly is. I am simply guessing on the auto lens cover. I suppose in the very worst case scenario, you can order the part, or perhaps even just remove it all together, though I would keep it until mechanical failure perhaps . . .
Franin
Franin
Thanks jostenmeat I might have to do that.
mozi121
Hey Franin,
Really waiting to hear from you the jvc thing..
thanks!
Franin
Franin
Ive heard nothing still. Actually it hasnt done it for awhile that I forgot all about it.
mozi121
Are you having the same issue mozi121?
Franin,
No, actually i heard the same problem some where, so I just thought if I can know the solution to it and increase my knowledge :cool:
Thanks,
Moiz
