Optoma TX728
Tech
Brightness (Lumens) : 2700 ANSI
Contrast (Full On/Off) : 2200:1
Variable Iris: No
Audible Noise: 33.0 dB
Eco-Mode: 31.0 dB
Weight: 4.0 lbs
Size (inches) (HxWxD) : 2.9 x 10.2 x 7.4
Std. Lens: Focus:
Manual
Zoom: Manual, 1.10:1
Throw Dist (feet) : 4.0 - 39.0
Image Size (inches) : 28.0 - 300.0
Optional Lenses: No
Digital Zoom: **
Digital Keystone: Vertical
Lens Shift: No
Warranty: 3 Years
Performance:
H-Sync Range: 15.0 - 100.0kHz
V-Sync Range: 56 - 85Hzf
Compatibility:
HDTV: 720p, 1080i, 576i
576p
EDTV/480p: Yes
SDTV/480i: **
Component Video: Yes
Video: Yes
Digital Input: DVI-I (HDCP)
Computers: Yes
Display: Type:
0.6" DLP (1)
Color Wheel Segs: **
Color Wheel Speed: **
Native: 1024x768 Pixels
Maximum: 1400x1050 Pixels
Aspect Ratio: 4:3 (XGA)
It will be at around 11 feet from the wall (aka the screen
) and according to a projection calculator will be around 87 inches. Any input?
Maybe somebody has one?
