I have just got a 60" LG plasma which I am trying to optimize. I've got a satelite receiver, 2 DVDs (one has a sound system included) and a VCR.
My specific questions are:
1) The coax that comes from the dish, is it a standard cable or are there different qualities
2) I have to extend the coax, and I used 3 connectors. Do I lose quality for doing do? Is it better to run the least possible connectoins and iseally try to have one only calbe from the dish?
3) Then, in the TV, there are: a) a rs-232 input (guess for the PC), b) a DVI (says its for the PC as well?), c) component input (Y, Pa, Pb), audio video sockets (AV4) as well as S Video, d) Antena input, f) 3 scart sockets (Av1, 2, 3) and an extra AV5 Audio video in sockets and S-video Audio in Sockets
As you can see there are many possible combinations..BUT, what is the best? I have heard different theories...S-Video is better..No, no, Scart is better???
4) Is it better to connect the different inputs into the TV or connect them to each other. If connected to each other, is there any loss in quality?
5) I heard cables make a difference. Can you reccomend one with a track record?
Thank you very much for you help,
Juan
