Any advice would be helpful.
bmac
I just put the finishing touches on my new system.I haven't hooked it up yet. I want opinions:Rotel RSX-1067 receiver, Panasonic PTAE 700U projector, Paradigm 110 L/R/C/ADP rears, Outlaw LFM-1 sub,tripp-lite line conditioner. Sony 400 disc dvd player. Do I need anything else? Oh yea, 12ga speaker cable and a samsung single disc unit.
Buckeyefan 1
Buckeyefan 1
How about a six pack of Blue Moon with slices of orange? Nice setup!
bmac
what about a screen?
I've read the comparisons on screens, where is the best place to pick one up?what about cables,any brand better than the others?
L
Leprkon
bmac
Leprkon good taste.
what about the superbit version of the fifth element?Is it worth the cash?
Rock&Roll Ninja
Rock&Roll Ninja
Set-up disk (I like Sound&Vision) and SPL meter (RadioShack).
And the 5th Element Superbit is worth every penny. Get Dracula superbit while you're at it (Special features get old after the first five or so).
bmac
Setup Disk
what does the video setup disk show me?I looked into one, but I wasn't sure if it would really help my system.
L
Leprkon
the Ultimate Edition is the best of both worlds. It gives you the SuperBit version of the movie, and a disk full of extras. It's the first package to give you both. :)
L
Leprkon
if you want to just try that out, there is a simple version called the THX optimizer on many newer THX disks, like the Star Wars Trilogy or King Arthur. It lets you make sure your brightness, contrast, sharpness, and some other settings are at the reference levels for a THX-quality picture. Look for the optimizer at the bottom left corner of the set-up screen.
If you like the results from those tests, it may be worth your investment for a mainline optimizing disk. :)
