AMG_Roadster said:
The wife has started her monthly complaining about my older 'ugly' Phase Tech Speakers. They are larger than she likes plus have the 'old school look'. I love they way they sound.
I had a similiar delimma when I moved to NYC. I was forced to leave my larger speakers behind in the move due to lack of space, but also because since there is really only one room to my apartment I didn't want to kill the look of the place with my oversized speakers.
AMG_Roadster said:
In my search I came accross the reviews of the Anthony Gallo Ref 3.1's. While I have yet to audtion them if they sound any where near as good as they look and the reviews say I will be happy to purchase them.
I will bet that we read the same reviews, primarily the ones posted over at 6moons, as well as a few others scattered about. I was under the same impression about these speakers before I had gone to audition them. I had listened to Maggies, Energy, Def. Techs, Vanderstien's, Mirage, and a host of others before finding the AGA 3.1's. To be blunt, they sound incredible. I have them jammed into some acoustically unpleasent placings in my room, less than two feet in front of floor to cieling glass mirrors, the left speaker sits approxamently two feet of an oversized, 80" tall x 24" deep armouir, and the right speaker within two feet of a chair and end table. Needless to say it's not my dream set-up but the set-up I have to work with.
The best thing you can do for these speakers is to go audition them. I found a dealer in Summit, NJ... Audio Nexus, that was incredible. I auditioned the speakers in a decent size room, but the speakers themselves were burried amongst other towers on either side. The still sounded amazing. In my current positioning of my room they are incredible as well. Would they better in a differet set-up, most definately, but I am very pleased with them. One of the reasons I went with the AGA's is because I was focused on Magnepan speakers heavily during my inital search and realized that my room set-up could not support the acoustic demands of the speakers. The AGA's are robust in being able to still carry their signature sound in less than ideal circumstances. This is obviously my opinion and I urge you to audition them and form your own.
I am running the AGA 3.1's as my main left and right channels, I have the new Reference Center channel which matches the sound perfectly, as well as AGA A'Diva Ti speakers in place as surround channels. I also opted to bi-amp the front speakers which makes them even better. I've had this set-up for a little over a month now and have been thrilled with it thus far. I listen to Classical, bluegrass, country, Pop, Metal, and also use it for heavy duty HT work and Gaming as well. The set-up performs flawlessly. If you have any questions regarding these just ask, I'll be happy to answer whatever I am able. Good luck in your hunt, but I do suggest you give the 3.1's a listen.
Respectfully,
~Andrew
