Beatmatcher247
Is ARC a pretty robust room correction system?
Anyone have anything thoughts or opinions about this product? I've got my system decided on for everything but the preprocessor. I like that this product has two bass management "profiles" for each of the speaker channels for painless switching between movie and music listening.
Anyone recommend anything else to look at?
O
oppman99
I have ARC on my D1 processor. I like it quite a bit. It's fairly easy to set up and it does everything right. I notice a significant improvement in SQ compared to when it is turned off. I'm not up to speed on the newest room correction software and I know there is better out there, but I think it will be significantly more expensive. It was well worth the cost to me if that helps.
