Just when I thought that there was nothing new in OTA TV reception, I found a new product that
might be something different. It is a
Winegard SquareShooter antenna. It was designed to receive TV VHF Hi-band (channels 7-13) and UHF (channels 14-69), the range of bands that all HDTV is using. The passive version has an average gain of 4.5 dB in this range, and claims a range of 35-45 miles for analog signals and 40-50 miles for digital signals. It will also work, less well, for VHF Low-band (channels 2-6). There is also an amplified version, that should deliver somewhat greater gain. It should be useful for urban and suburban HDTV reception for people who want an alternative to more expensive and often less reliable cable TV. See the
spec sheet.
It was clearly designed to look similar to 18" dish satellite antennas. It is square 16 × 16 × 4" and covered in gray plastic similar to dish antennas. The small size makes it easy to install in variety of locations.
Winegard has patented it and claims it was derived from military designs never used in home antennas. They claim it is especially good at rejecting multipath signals common in urban/suburban areas that cause ghosting in analog TVs.
