As far as subs, do you think it is worth waiting and buying the PB13 ultra in a couple months or is it overkill for my smallish room?
YMMV, and overkill is one of the hardest things to define, IMO. The ONLY worry about the PB13, for me, is if the size is too large aesthetically. If this is a concern, I would do some sort of cardboard mockup to really see. It's VERY difficult to picture the differing sizes, mentally. All subs seem to look like the size sometimes on a computer screen. Otherwise, it's a real value leader for the price point.
The only other consideration I can think of is taking a tad bit away from the sub budget, say for the value oriented PB12, and applying the savings towards bass traps for smoother in room response.
Also, any thoughts on eD subs? I have only heard them in cars, but people seem to be pretty impressed with them.
Not very pretty; value oriented. Some people, even owners, say it's like the finish on a truck bed liner.
If you can't tell I have a hard time buying danything I can't touch, see and listen to, so the ID subs make me a little nervous. Thanks again.
I absolutely understand. When I first started on this madness, I met and spoke with double digit dealers. I have no problem with the concept of ID, and in fact often recommend certain ID brands. Often this includes Ascend for speakers and SVS for subs.
