Another Sub Advice Thread
DocS
Great site! I've lurked a long time, and found lots of informative stuff. I've got a very basic setup at the moment, and I'm looking to build a system I love one item at a time. The present system:
Pioneer VSX-815, Pioneer DV-285
Athena Audition C-1, B1 mains, R1 rears
The obvious first step is the sub: I don't have one at all right now. I am leaning strongly towards Axioms for the speakers a bit down the road, and upgrading the receiver & (HD?)DVD are at least a year off.
The Canadian pricing situation, my budget and the wife veto have led me to three subs, all of which would cost me roughly the same (within about $75) to my door:
HSU VTF-2
HSU STF-3
SVS PB10-NSD
For various reasons (including shipping costs that would nuke my budget) my auditioning opportunities are basically nil. The equipment is in one corner of a 25X12X10 room (the listening position is ~8 ft away). It's in an apartment, so I will not be listening at extreme levels. Use is about 70/30 for music/HT. Obviously, I'd like something that'll sound nice with the Athenas right away and will still satisfy as I upgrade.
So, how do I decide? I've read the reviews (and the arguments) and I can't say I'm any closer. Is this a no-lose where I can flip a coin and be well-set with any of them? Are there particular strengths and weaknesses that apply to my equipment or room? Are there other subs I can consider in Canada in the same price range? Given that both are within budget, is there any reason I would choose the VTF-2 over the STF-3?
Thanks in advance
billy p
billy p
Those subs are fine choices! The hsu stf 3 price is right in there with the svs pb12 nsd and the sb12 plus!! So, now you have five choices;) Do yourself a favor if you havn't already check out www.electronicsforless.ca they sell both and the prices are very competitive:). I myself am looking at the svs sb12 @ $799.00 cdn, it is small and not obtrusive and would be very high on waf scale! Albeit your room might be better served with the pb12 nsd of stf 3 but go the 12" for sure!!
DocS
Thanks for the advice. Unfortunately, I'm still not decided; it seems as though I need to get to EFL/SonicBoom and have a look/listen firsthand.
