Thanks a lot you guys, I think you hit the nail on the head.
After reading your posts and paying particular attention to my position and movement during the measurement procedure, I have seen a major improvement in the repeatability and stability of the meter. I am quite amazed how little movement it takes to change the readings!
I have found that after establishing my reference point at 1kHz and 4kHz, if I change the position of my body only slightly the effect on the meter can be several dB.
After this revelation sank in I ran through the tones again while remaining as still as possible, and am happy to report that with only a few exceptions most of the readings were between 0dB and -3dB.
Thanks for helping me clear this hurdle. Now on to the next …
Dumar
