Hello... I recently picked up a used Panasonic 56" projection TV to replace my Sony that was breaking down. The Panny looks great. It is about 5 years old.
The issue I found with it (after bringing it home and setting it up) is that the image appears to have "stretched" and moved down. What I mean is that the image appears to finish up about 1 inch off the screen to the top and sides, and the overall image has "slipped" about 2 inches down. On all the settings. For instance, the ticker that you would see on ESPN or during a football game at the bottom of the screen is actually BELOW the bottom of the screen so it is not visible. I've cycled through all the aspect settings (zoom, full, justified, etc) and it is the same. Also, when there are the horizontal bars on the top and bottom of the screen with a 16:9 image the top bar is twice as large as the bottom.
Any idea what is causing this? I was thinking that a professional calibration might fix this issue since I can't seem to "move" the image. Remember with the old tube tv's you could move the image up/down and right/left to center it? That seems like what needs to happen here... any suggestions?
thanks!
