Another DIY cable post...
adwilk
adwilk
So i'm interested in this DIY cable stuff and i made a simple digicoax last night, and i must say, it sounded a lot better than that old yellow video cable i separated from the audio cables i got from radio shack. I'm just kidding... it did seem to appease my mental curiosity a bit though. So i was wondering... if you use a good coaxial cable that already has the f connectors on it, could you just use the f-rca adapters, your would you really be that much better served to cut the f's off and solder on new rca adapters?
EDIT: and just to make sure, assuming i home-make them, Every cable with an RCA plug can be interchanged??? IE subwoofer/digicoax... red/yellow/white to use with component video. As long as they are good cables..
Why would you bother buying a cable and cutting them off when you could just get some coax cable to use with the correct connectors?
jp8869
The way to go if you want to make your own coax rca cables is to buy a roll of quality rg-6 cable (you can buy a 500 ft roll for under $100) buy a compresion tool capable of putting on compresion(snap-nseal) rca connectors ( you can buy a kit from parts express with a crimp tool stripper tool and a variety of connectors including some rcas for like $90) The investment in tools is a little expensive but once you have them you can make all the custom length cables you want and the rca connectors are chaper than f-rca adapters and you have less connections.
http://www.************.com/pe/showdetl.cfm?&DID=7&Partnumber=360-047
Hi Ho
Hi Ho
I find the twist-on type connectors to be the easiest to use and provide as solid a connection as the crimp-on types with no tools required.
I have crimp tools and all the works but I still prefer the twist-on connectors. They look nicer too.
adwilk
adwilk
Welll, i wouldnt actually be buying the cable. I already had some high quality coax cables that are already terminated. I was just wondering what would be the best way, in terms of quality, to go RCA....
Hi Ho
Hi Ho
You could just buy some connectors like THIS. There is no need to cut off the existing terminations.
If you don't want to pay shipping, they sell those same connectors at Radio Shack.
Hi Ho
Hi Ho
I forgot to mention that. I wasn't suggesting that he buy them at Crutchfield. They are cheaper at RadioShack.
jp8869
I hate em I hate em I hate em. I guess for home audio the twist ons are ok. I am a marine electronics tech and have replaced many of them on boats cause the cheap@@@ people put them on a boat when for an extra .20 cent apeice they coulda used snap-nseals
oops sorry about the rant but there are some very nice looking compresion rcas Ill try to find a link to them and post it later
Hi Ho
Hi Ho
A boat is a completely different situation than a house. I see no problem in using twist-on connectors indoors.
