My new media room has a couple odd features that complicate Atmos height speaker positioning and format (7.2.2 or 7.2.4??). Here's what I'm working with....
Room is W12.5' x L22' x H7.5'. As usual, doors and an annoying (and irremediable) soffit and column limit height speaker placement. These can be seem in the pix. The stool is more or less the viewing position with the display on the wall behind the bright light. The bed layer placement doesn't present any obvious problems. Finally, height speakers will be bookshelf speakers on adjustable brackets regardless of positioning and number. For a variety of reasons ceiling speakers are out.
My hope is working up to a 7.2.4 setup, though this may not be practical. Easiest however, by far, would be a 7.2.2 configuration with the height speakers located in the yellow areas shown below in Plate 1. The angles and placement seem consistent with 7.2.2 guidelines. Positioning could easily be closer to the center of the room along the soffit - I need to measure exact position more carefully, but the point is that 7.2.2 seems pretty east to implement.
Plate 1
Next we get to possible 7.2.4 positioning. See Plates 2 and 3. The 2 front and rear height speakers could potentially be placed more-or-less as shown in the red and green positions. The front speaker (red) seems best in the soffit/column corner. That's a bit low perhaps, but if mounted on the ceiling (yellow), as with the 7.2.2 config, it's too far back. It could be in front of the soffit on a ceiling mount with an arm. This would still be low so as to not be obscured by the soffit. but still possible
Plate 2
Plate 3 shows the proposed positioning looking towards the back of the room.
Plate 3
Any thoughts on the height positioning/configuration would be very welcome. By my reckoning the 7.2.2 positioning seems truly by-the-book. 7.2.4 less so since the front height speakers would be lower than ideal. So, just stick with 7.2.2? Or go for 7.2.4 despite imperfect positioning? Other options, such as 5.2.X of some sort? As we learned from Jethro Tull, "Nothing is easy." Thanks and cheers,
