Amp options
Mike,
I have to disagree with your logic. The digital Rotel amp may have lower distortion or other improvements, but a 100 Watt digital amp does not equal 200 Watt solid state amp. Watts are watts.
If you are looking for 200 Watts x 7, check out the Emotiva MPS-1 for $2k from av123.com. It is well reviewed and recommended by AH. It is a modular design with up to 7 mono block or stereo modules, so you can also buy it with 5 channels to save money and add the extra 2 channels later.
