Hi All!
If it comes to speaker connections and different possibilities coming from available amp outputs I'm a rookie, so will be glad to hear a piece of advice from You
I've just get occasion to get amp Xindak xa6950 (II) and wondering is there possibility of connecting currently owned active subwoofer somehow to it (stereo RCA input only)? Considered amp has only stereo separate routes (balanced or RCA). Mine current amp has additional sub output beside standard high level speaker outputs.
Got two options in my mind, hope you can advice if it will work or if there is other option or no possibility of such connections.
1) Separate singnal from one speaker
2) Since before amp there is a DAC, put signal to sub separately from DAC.
Thank you in advance for suggestions!
Regards,
Luke
