Many, (most?), AVRs w/ multiple zones require analog inputs for the analog Zone-2/3 outputs, if you play them and your main zone at the same time.
I forgot... there is an exception that you should check w/ your choice of AVR.
Without using separate analog inputs, (I mean using only HDMI to connect all components), you CAN play the same source in multiple zones at the same time. However, the AVR may "dumb down" the signal in your main zone to Stereo only.
Here's what I mean. Say you have a Satellite box, Bluray player, Receiver, and TV all connected w/ HDMI cables. Your AVR has 9 amps. In your Main Zone, you have 5.1 speakers. In Zone-2 you have Stereo, (2 speakers), and Stereo in Zone-3.
You turn on the Main Zone and put a movie in the BDP. It provides 5.1 audio for your listening pleasure. Now you decide to also play the movie audio in Zone-2 so your wife can hear it while she folds laundry in the other room.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
)) You turn on Zone-2 and select your BDP as the source.
Depending on your AVR, you could get movie audio in both rooms, BUT your Main Zone "dumbs down" from surround to stereo. Using only HDMI connections, your AVR cannot decode surround for one zone, AND stereo for another zone at the same time.
The "fix" is to use HDMI cables for your main zone surround, AND analog cables for your Zone 2/3 selections.
