To answer the above questions, my speakers are all SVS. Prime Pinnacle for L/R (88 sensitivity), Ultra center (87 sensitivity), Prime bookshelves for surrounds x4 (87 sensitivity). Monoprice alpha in-ceiling for Atmos x4 (88 sensitivity). They are all rated at 8ohm, but I saw that the Pinnacles can hit around 5 at a certain frequency. I don't listen at 0 at all. Usually -15, give or take. So basically, if I use that in the calculator, then at -15, which would be 70db, based on 85 reference, I would need .15watts, with 90db peaks at 15watts. So as Peng said, I wouldn't benefit from and external amp.
