That's a fair question. Yes, I am currently using it to power the L/R pair, and it seems to be... okay, I guess? Qualitywise I don't have any complaints, other than an admission that based on my auditions I might like the sound of good Class AB amps a little more than the one Class D option I've heard (and own). I admit I don't fully understand the implications of the numbers, it's a little hard for me to understand why I'm likely to need more than 50W per channel to handle a 90dB volume (which for me is right on the edge of uncomfortably loud for sustained listening) to a seating position 11' away from the speakers. That said, I'm not comfortable squaring off my rudimentary understanding of this stuff against what KEF has written for their specs. My concern with pursuing a power upgrade was more about hedging against premature wear from underdriving the speakers on those transients and the assurance that the amp is not actually clipping some elements that I'm not aware of.
As ADTG said if you are fine without cranking up the volume, then your M27 should be more than enough. I don't know the range of the AVM 70's volume, may be
@Cos or yourself can tell us. If it is say 0-100 and you are getting loud enough spl at less than 70 then replacing it with any of the amps you listed won't do a thing for you. Power not required/used will not change a thing just because it is available, and we all know specs better than the level considered well below humans threshold of audibility is also not going to help. For example, the AHB2, under one test condition, has THD+N 10 dB less than the M27, but even golden ears cannot tell a difference, not in theory, all else being equal.
You can also use an online calculator to find out how much power you really need but again, going by the volume (actually would be better to have the level trim settings as well just to be sure).
The NAD M27 has great specs, the only amp you listed has a chance to beat it in terms of audio specs is the AHB2 but I think you know that already. The chart below only shows the results of one test, but the M27 did extremely well on the other tests performed on that review as well. If I agree with others, if you need more channels just grab another Hypex or Purifi amp. Even if you have money to burn, you can burn them on things that will actually make a difference, such as acquiring the best available source contents. In my experience, given the nice equipment you already have, top recording quality contents will give you the best bang for the buck, not a better/more expensive power amps.
Review and Measurements of NAD M27 PWR Amp | Audio Science Review (ASR) Forum
